Let's start here: Ralfy. This wonderful gentleman is a treasure. Honest, transparent and just like us - just with a better collection and a great palate. Just like us, he buys his own spirits. Just like us he cares not what the bottle looks like, but rather what's in it. Just like us he rejects marketing, coloring and anything we'd call dishonest or impure. But for purposes of this post...
He adds water to whisky.
And how is that? It would be fair to say that knowledgable whisky tasters' and reviewers' consensus is that most spirits taste best in the 43 to 45% range. Tasty, but not dominated by the alcohol. That's exactly why many drinkers get woodies over a bottle delivered at "barrel strength". And just why is that? Do they intend to just pour one, throw it back and cry out "Argghhhh"?
Hardly.
They are pleased because of two things: first, that the barrel strength bottle is brimming with flavor missing in a pussified 40% spirit and second? Value. They know that properly diluted that bottle will go a lot, lot farther to provide drinking enjoyment. Watch Ralfy - when he tastes a high proof whisky well yes, he'll note its aroma and and record a tiny taste but what happens then? Yup, out comes his precision dilutring instrument - his famous teaspoon - and into his dram goes two to three teaspoons of water. Indeed, he will often add a small splash to even lower proof whiskies for yet another reason.
It releases flavor. The lower proofs don't really need dilution, but the addition of water is known to chemically release hidden flavors. Trust me this works. All, in all the addition of water is almost mandatory in tasting.
But not the arsehole faux rum reviewers!
I can't tell how many of these self-inflating reviewers actually make it a point of pride to taste an overproof at full strength, then explain how manly and strong it is - fully described with the words of warfare and how they - our heroes - survived the experience. They then actually review the OP on the basis of the overpowering alcohol and bite and their scores - and the otherwise fine rum - suffers. Read a review of Wray & Nephews OP sometime and you'll see what I mean.
W&N is actually a superb overproof and earned a rare and glowing 5-star review by Dave Broom, who called the best overproof rum you can buy. Listen to his description...
Ask yourself - is this what you got from W&N? And then - but did you taste it with water? I can tell you that most of the fat faux reviewers didn't - to the contrary they made sure NOT to add water and thence to explain just how exciting it was to face off with firewater. They promote their ignorance as a point of pride. The truth be told, it is possible to obtain some of Broom's (or your own) qualities with some very, very slow and careful microsips. But I'd venture a guess that most don't even do that."Nose is clear and bright. Rounded, rich with ripe banana, molasses, lime and a touch of cashew. Has real substance. Good, clean spirit. The palate is ripe. Showing notes of banana, grass, nuts and sweetness. That cashew note keeps things crisp. A grassy and long finish.
The best overproof on the market. Punchy but classy"
When we reviewed W&N we were thankfully aware of the need to taste it properly, and did add water very carefully (to follow). You can read the review for itself.
So how to proceed?
If Ralfy et al has convinced you the next issue is how to proceed. Now for the anal retentive among you - yes, you can used distilled. Want to do that? Go right ahead. But unless your tap water is pretty horrible, that'll work too. And how to add it? Again for the AR's, you could use a little eyedropper or for the rest of us Ralfy's sophisticated teaspoon will do just fine.
Now of course it's good to first taste the spirit full strength for a baseline. First up? Breathing. Let the firewater breathe fer gawdssake. This is not a 40% where you just dive it. Leave it on the table for at least 5 minutes. You may even get some aromas then, but when finally ready to actually nose, do approach carefully, Don't just jam your nose in there, but wave the glass a safe distance under your nose and gradually and carefully approach it.
When ready for a taste, proceed likewise - very, very slow and measured micro-sips. Very tiny. Don't pay any attention to the first sip or two as your tongue needs to adjust a bit. Don't push it, you're just going for an imipression. Now your'e ready to really taste it...
If it's lower proof you might add a few drops at a time as you continue to nose and taste it. Ralfy has been known to just plop in a teaspoon. Remember you can always - slowly - add more water and see what happens. Note the flavors opening up. For a true OP you can add a teaspoon (to an ounce) right away. Ralfy may go up to 2 or 3 of them.
A great rum to try this with is the aforesaid Wray & Nephews. See if you can get some of what Dave Broom found and see if you agree. See if you are getting more aromas and tastes (you will).
Adding water needs to a regular part of tasting almost any spirit from 40% on up, but absolutely on true overproofs (50% on up). To fail to do so is an unqualified mistake.
