Mac Baren Navy Flake: first experience
Mac Baren Navy Flake: first experience...
What to me is "Navy Flake" and what caused me to try it, first the history. This form of tobacco is directly attibuted to the sailors of yore. In those days a sailor was lucky to own a change of clothes. Life on the sea was very hard, and joys were few but valued. Rum and tobacco were two of them. To save space the tobacco was moistened with solutions of rum, molasses and spice - then rolled and squeezed into a thin "rope" and coiled into a small compact size that could easily be stored, carried and protected. Later and in like fashion tobacco could be compressed into blocks which could be cut into strips, cubes or lasagna like layers called "flakes".
These were appreciated by mobile sailors and outdoorsmen not only for their convenience but because when "packed" into the pipe burned much more slowly and evenly, and required few less "relights". Modern flakes are much less aromatic than the old get-laid blends that you tolerate on the basis that sex trumps taste, lol. Trust me.
With a history like that and especially noting my love for Charles Tobias' Pussers, it was almost a no-brainer. Second, it hardly hurt that no less than our good da'rum made clear that Navy Flake is one of his favorites. He rightfully poo-poohed the less expensive but amazingly popular 1-Q: a very aromatic tobacco that is reputed to be the largest selling blend in the world. Apparently sex is a worldwide obsession, who knows, lol?
An idiot tries Flake...
As background it's important to know that 1-Q comes in shredded form in a typical ziplock type bag. The challenge of this finer, shredded tobacco is what we'd think is simple, ie to just stuff some in your pipe, light it and have at it, right? Wrong. Turns out "packing" is actually a bit of an art. This is not just the usual fine point obsession that afficianados of anything fall into, but are real and necessary techniques. Pack right = enjoyable smoke. Pack poorly = frustration, poor taste and a horrible experience.
Shredded tobaccos are not easy to pack, but I've learned to do a sorta, kinda, halfway decent pack but which still caused more relights than I'd have liked. Now that I'd spent more serious money for a fine Danish Navy Flake, and I was determined to have what da'rum promoted as one of the finer experiences in pipe smoking.
Now. In accord with its cost, Mac Baren's Navy Flake comes in a classy, vacuum sealed tin. It's so well sealed that it takes a bit of work to break the vacuum. Inside and wrapped in a very high quality gold foil is a block of sliced "flakes" of "Navy" tobacco. Compared to the 1-Q's focus on aromatics (including vanilla) , this Navy Flake presents as what it is - a block of rich tobacco, deep aromas, slightly sour, vegetal and with just a hint of rum. One seems oriented to pleasing the ladies in the room; the other is clearly destined for the smoker. We'll see.
Packing the pipe with flake...
Packing flake is promoted as tricky, but once accomplished is supposed to be easy and to provide a MUCH better experience - if - the proper technique is used. Yes, you can break up the flake into shreds, but like 1-Q it may likewise not pack or smoke nearly as well. OTOH, if you can learn to fold and stuff it in properly you can look forward to a much more enjoyable time.
Of course I'd prefer the folding method, as described thusly by da-rum...
"Once satisfied take the piece of flake and fold lengthways in half the widthways. Give it a twist in your finger and it should start to come apart in sections but stay whole in others. Just stuff that in your pipe with the bent end down and shaggy end up. This is trial and error to pack strength but be prepared for a couple of failures. No big deal. Tip it out and start again. If it falls apart so much that it is unmanageable as a fold and stuff method then treat it as a ready rubbed. Fold and stuff method can take a little effort to get lit and going but once it is smoking well it usually requires very little maintenance."
In my research I also learned that the ideal pipe may be on the smaller side, with the interior of the bowl having more-or-less vertical sides. This seemed logical as properly packed folded flakes are dense and will lead to a VERY long smoke in larger pipes. The vertical sides advantage should be obvious, as the folded flake forms a roughly vertical cylinder, a similar shape.
So I opened the tin and attempted to peel off a single flake and I failed. The rectangular flake had broken in half. WTF I thought, I'll just try this with the half-piece. I folded it parallel to the long side - twice - then inserted it into the pipe to see whether (ideally) half its length would fit into the pipe. If so this would mean all I'd have to do would be to fold the long cylinder in half and voila! A perfect fit. But when I tested the fit, the cylinder was a bit long. Again maintaining my WTF mood, I proceeded anyway folded my cylinder in half, pressed it into the bowl and yes, it was too long.
My solution: I just stuffed that down in too and good news - turns out a half flake seemed the right amount to fill my pipe. Tested the draw, thought it a bit light, and pressed down a bit more. So what happened?
The result...
It worked. After a couple of initial lights to try to create a decent sized coal, the pipe then stayed lit for much longer than the 1-Q. Yes there were a few relights, but nowhere near as many, and nor nearly as frequent. As for the Navy Flake itself, my impressions are hard to describe. It seemed fuller, more cigar like, but with a pipe like quality of warm and engaging pleasantness. Sue Sea's reaction is illustrative: she hates flavored rums and flavored tobaccos. She found the room effect of the 1-Q tolerable but she had no interest in smoking it. The Navy Flake? Completely the opposite - she found it authentic and engaging.
Like a dangerous rum, too drinkable (think Matusalem).
Great! I'm glad you had at least a mildly pleasant experience with this flake. You will get the packing down to an art in a few pipes time and be confidently stuffing that flake in like a pro in no time.
Don't worry about a few re-lights that's to be expected. When you get your first one or two light bowl you'll be happy as Larry. Even 20 year pipe smoking veterans must relight their pipes it's just the nature of the game. It's only when the relights become so frequent that it is impossible to sit back and relax that something must be looked at. It will only be one of two things 1) Pack tightness 2) Tobacco moisture level.
Stick the tobacco in a jar now Jimbo as it won't last long in the opened tin. It'll dry out too much.
I hope you enjoy this tin as you work your way through it, I can only imagine that your satisfaction will increase.
Storage question...
For the moment I've stored the Navy Flake tin into a larger, higher round tin - figuring that two sealed tins would inhibit drying out. But Sue Sea does have some 1 pint glass canning jars - the flakes will surely fit I know, but there will be a good bit of unused space. Will this work, or should I look for a smaller screw top glass jar (old coffee jar)?
Tx in advance...
The flake will last about a week in the double tin set up before you start noticing that it's getting particularly dry. With the weather the way it is over your way it's best to be safe than sorry. So..
A pint jar will have too much room but that can be filled with stones or something to take up the airspace if you absolutely must.
However perfect solution is a ball jar or screw lid jar about 1/4 pint size or smaller. (It doesn't hurt the tobacco if you have to jam it in a jar, I have a couple like that that are about 8 months old and are still perfect.)
If you do utilise a second hand jar be aware that any aromas will go into the tobacco and don't use a jar with a plastic lid.
Use glass not plastic.
PS next time you open a tobacco tin just locate the indent along the lip of the lid, slip a coin or bread knife underneath and twist. You'll hear the air release.
An update and a thanks...
Let's say this: when I first fired up my straight-stemed cob with the 1-Q, and despite my pleasant memories of Middlton's Cherry Blend from 40 years ago - even after a few pipe fulls, well, it just wasn't happening. 1-Q was supposed to be the #1 selling pipe tobacco worldwide, gentle and fragrant but that wasn't how I experienced it. Frankly, I wasn't all that sure this was for me. Not to mention this tobacco just didn't want to stay lit.
So natch, when my trusted friend and partner in shutting down Diageo - just kidding corporate hit men, just kidding - suggested I reserve a pipe for MacB's Navy Flake I trusted him, and gave it a try in the pipe I preferred anyway - my classic looking bent stem cob. Sherlock Lite, doncha know? Sure ya do.
It took me three sessions to get develop a charcoal layer down to the bottom of the bowl and again to be fair, it still wasn't happening. Yes, I knew the the Navy Flake was supposed to burn better and stay lit - which it did - but the reported easy tongue and enjoyment wasn't quite there.
So today I tried again
The bent stem seemed charred, and once again I packed it using da'rum's method using the full piece of tobacco - which seems to be just about right. And this time something had changed. It burned well, allowed nice sipping, and somehow was rather pleasant. Just enough aroma, but not a bit more. The Flake to me seems entirely authentic and just what I'd imagine a BRN seaman would enjoy.
As a former sailor I've been at sea - in a blow and in the calm. In the dead calm and blazing heat, and fighting the tiller in a blow with four frightened passengers. Watchin a blazing sunset fall, and a full moon rising as the bow sliced through a mirrored sea back to port.
This tobacco is exactly that.
What changed? I don't know for sure, but I'm going to guess a cob pipe needs to break in. Perhaps the early smoke is part burning cob. But whatever it is, it is better and more pleasant. Time will tell. For all this, I thank the Aussie...
Nice one Jimbo glad to hear it's working for you.
A pipe in the mouth makes it clear that there has been no mistake–you are undoubtedly a man.
- A. A. Milne
Welcome to the club :D
"The fact is, Squire, the moment a man takes to a pipe, he becomes a philosopher. It’s the poor man’s friend; it calms the mind, soothes the temper, and makes a man patient under difficulties. It has made more good men, good husbands, kind masters, indulgent fathers, than any other blessed thing on this universal earth."
– Sam Slick, The Clockmaker
I'm really glad to read that you have packed and smoked your first successful bowl. You will get a feel for it as you go along and it will be regular if not common thing. As I now have a cob here, I can tell you that you can really stuff that pipe as the draw is so open that it would take a heavy hand to start to hinder it. Use my flake method but don't be afraid to stuff the shaggy end into the top of the pipe and squish it down. Test the draw (it should still be free) and fire it up. Do a first light, touch the flame to all exposed tobacco bringing up a coal and then let it go out. Tamp it flat (not down) and do your 'true light'. Again touching the flame to all exposed tobacco getting a uniform coal and then sit back and relax.
You are at the moment working your way through a tin of Burley, Cavendish and Virginia blend. There is a lot of different blends that we'll get to when you're done with this. I think I know your taste direction and will come up with a suggestion probably in the area of Virginia/Burley or Virginia/Burley/Kentucky and maybe with Perique the holy grail of spice tobacco. However, all in good time.
Enjoy the rest of the tin, savour the experience and enjoy your meditative moments.
I'll leave you with this
By Johann Sebastian Bach,
Whene’re I take my pipe and stuff it
And smoke to pass the time away,
My thoughts as I sit there and puff it,
Dwell on a picture sad and grey:
It teaches me that very like
Am I myself unto my pipe.
Like me, this pipe so fragrant burning
Is made of naught but earth and clay;
To earth I too shall be soon returning.
It falls and, ere I’d think to say,
It breaks in two before my eyes;
In store for me a like fate lies.
No stain the pipe’s hue yet doth darken;
It remains white.
Thus do I know
That when to death’s call I must harken
My body too, all pale will grow
To black beneath the sod ’twill turn.
Or when the pipe is fairly glowing
Behold then, instantaneously,
The smoke off into thin air going,
Till naught but ash is left to see.
Man’s frame likewise away will burn
And unto dust his body turn.
How oft it happens when one’s smoking:
The stopper’s missing from the shelf,
And one goes with one’s finger poking
Into the bowl and burns oneself.
If in the pipe such pain doth dwell,
How hot must be the pains of Hell.
Thus o’er my pipe, in contemplation
Of such things, I can constantly
Indulge in fruitful meditation.
And so, puffing contentedly,
On land, on sea, at home, abroad,
I smoke my pipe and worship God.
http://www.youtube.com/watch?v=fkgKdVzexsI
PS; Packing a pipe perfectly every time is a goal we all strive for and only a few of us achieve and I don't even believe those that claim to have achieved it. I pack good pipes 95% of the time but stuff it up regularly enough to remark on it. What I should do is let the pipe go out and repack it, what I actually do is fight the thing until it's all smoked, I've used half a lighter of gas and am completely unsatisfied with what my last hour brought me. As I said 'pipe smoking is an art'
